Activity Forums Maxon Cinema 4D Setting alpha map in cinema 4D
  • Setting alpha map in cinema 4D
    Posted by Ken Chan on March 28, 2007 at 6:32 pm
    I am trying to do a card opening intro for my video, in which the card opens and flip to a page which will transit into the video footage that will be edited in Final Cut.
    I have a card bottom texture which I assign the texture with alpha turns on, so that portion will be transparent for my video to show through in final cut. However, after I rendered (quicktime animation codec, millions colors +) and import it into final cut. The alpha does not show, though the item properties recognise it as a straight alpha.
    Have I missed out any important steps that I should be doing in order to get this right?
    Please advise guys.
    Ken
    Ken Chan replied 19 years, 6 months ago 2 Members · 4 Replies
  • Brian Jones
    March 28, 2007 at 11:33 pm
    Should work straight or not, unless you have something behind the card that’s blocking the alpha.
  • Ken Chan
    March 29, 2007 at 2:10 am
    It does not work, I do have a ground background behind the card bottom which I assign the alpha, but I cannot turn it off as I need it to be rendered as well. I though I can assign a alpha texture to the card it should just rendered that as an alpha map, apparently it does not work thay way. Any way to do this?
    Ken
  • Brian Jones
    March 29, 2007 at 4:11 am
    Alpha only works (in the compositing sense) if there is nothing behind it. You are wanting a “put a hole through everything here” kind of thing. Don’t know if it exists. But…
    -Render the ground/card as a seperate passes or,
    -instead of alpha use a matte color in the same spot, composite using chroma or,
    -place alpha on the ground behind the alpha on the card or,
    -bring the footage into C4D and composite there…
    probably more ways…
  • Ken Chan
    March 29, 2007 at 10:14 am
    Hi Brian,
    Thanks for the info, I tried to render it with a separate pass using multi-pass, put it in the image mask in final cut filer does not seems to work.
    Seems like I have to use the chorma key option and use the card bottom as a matte object and key out in final cut
