Activity Forums Adobe After Effects Expressions setting a range
  • Posted by Jamil Yamani on May 17, 2012 at 1:56 pm
    hi all
    i have been using some code to sample some audio and it has been working fine up until now.
    i am using a slider value to drive a position on a transform:Repeater1 on a Shape layer, please see code below
    the values should read between 50 and 100 but they are not.
    can anyone see why?
    cheers
    jamil
    x = comp("Audio Amplitude").layer("Bass").effect("Final Range Value")("Slider");
    linear(x,0,20,50,100);
    [x,0];
    The Electric Canvas
    Large Format Projection Specialists
    Sydney, Australia
    Jamil Yamani replied 14 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 17, 2012 at 2:21 pm
    You’re not incorporating the result of linear() into your final value. I’d guess you need to modify it like this:
    x = comp(“Audio Amplitude”).layer(“Bass”).effect(“Final Range Value”)(“Slider”);
    newX = linear(x,0,20,50,100);
    [newX,0];
    Dan
  • Jamil Yamani
    May 17, 2012 at 6:00 pm
    Dan
    This isn’t the first time you have helped me thanks very much! It worked a treat.
    Jamil
    The Electric Canvas
    Sydney, Australia
