Activity › Forums › Adobe After Effects Expressions › Setting a Mask Name as a variable
  • Setting a Mask Name as a variable
    Posted by Ryan Jones on October 3, 2017 at 6:58 pm
    Not sure if this is possible. I have a white solid I’m using as an alpha channel for a painful rotoing job. I have several masks and would like to name them 1-160 (there are 160 frames in this comp) and have the expression say if the timeline is at 50 frames, then Mask 50 will be 100% opacity and zero before and after.
    The manual expression I’m using now is– Mask name is “50” and the opacity of the mask is as follows
    f=50;
    x=timeToFrames(time);
    if (x==f){100}else{0}
    I’m trying to avoid changing the value of F for every mask. I’d rather just name it and have F pull the Mask name so I can just duplicate or cut/paste the expression without modifying it. Is this even possible?
    RSJ
    Ryan Jones replied 8 years, 12 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 3, 2017 at 7:36 pm
    This should work:
    f=parseInt(thisProperty.propertyGroup(1).name,10);
    if (x==f) 100 else 0
    Dan
  • Ryan Jones
    October 3, 2017 at 7:38 pm
    Well, adding this to my little book of expression shortcuts. Thank you so much!
    RSJ
