Activity › Forums › Adobe After Effects Expressions › Set transparency if color is white
  • Set transparency if color is white
    Posted by Mats Jacobsson on February 12, 2010 at 12:33 pm
    Hi!
    Coukd someone please tell me why this expression isn’t working?
    I have a Fill Effect on a Solid that is controlled by a Color Control in another Comp.
    I want the transparency of the Solid to be 50% only if the Color Control is set to 100% white.
    I get 100% transparency even if it’s white.
    And why is there four arrays? Isn’t it RGB?
    if (comp("COLOR").layer("Null 2").effect("COLOR 2")("Color") == [255,255,255,1])
    transp = 50;
    else
    transp = 100;
    transp
    Dan Ebberts replied 16 years, 7 months ago 2 Members · 2 Replies
  • Mats Jacobsson
    February 12, 2010 at 1:14 pm
    Ok, i figured out that the fourth array is the Alpha. I also tried [1,1,1,1] but still the same result
  • Dan Ebberts
    February 12, 2010 at 3:15 pm
    Expressions expect color values between zero and one. Try it this way:
    C = comp(“COLOR”).layer(“Null 2”).effect(“COLOR 2”)(“Color”);
    if (C[0] == 1 && C[1] == 1 && C[2] == 1) 50 else 100
    Dan
