Activity › Forums › Panasonic Cameras › Set Production monitor for P2 field playback
  • Accountneedsrealnameupdate
    March 10, 2007 at 2:37 am
    No problem, it’ll work fine. The composite out from the camera is always 60P, (in 720P). When you shoot 24p it’s 24p over 60, when you shoot 24PN, it still comes out of the camera as 60P, but only 24 of 60 frames are recorded. No matter what the frame rate, It’s all the same to the monitor.
  • Frank Nolan
    March 10, 2007 at 9:00 pm
    [Rumpy the Cat] “The composite out from the camera is always 60P, (in 720P).”
    The composite out of the camera in NTSC is 480 only.
    You would need to use the component out and make sure you get the optional component I/O board (IF-C101CMG) for the monitor.
    March 11, 2007 at 12:35 am
    You’re right Frank, I meant component. I really should proof-read before I post.
  • Arthur Luhn
    March 11, 2007 at 8:11 pm
    >>>make sure you get the optional component I/O board (IF-C101CMG) for the monitor.<<< That adds about $5-600 to a monitor that is already $700, is there a moderately priced monitor out there that bypasses this and is good enough to use as color and lighting proofing? Thanks..
