Activity Forums Square Box CatDV Set Poster for multiple clips at once
  • Set Poster for multiple clips at once
    Posted by Mike Ostrowski on September 23, 2013 at 6:07 pm
    Hello,
    I’ve rebuilt my catalog of several hundred clips with three thumbnails for each clip. I get the option of using the midpoint thumbnail as the poster, but I’d like to use the end (or 3rd clip) for the poster. I know I can set this individually, but I was wondering if there is a way to do it for the whole catalog.
    Stuart Peck replied 12 years, 11 months ago 3 Members · 2 Replies
  • Dougal Matthews
    September 25, 2013 at 1:15 pm
    I’m afraid that there’s no way to set this automatically to default to the last thumbnail
    currently the only solution is to set the desired thumbnail manually clip by clip
    Improvise Adapt and Overcome
    but remember: out of good , quick and cheap
    you can only pick TWO …
  • Stuart Peck
    October 8, 2013 at 6:31 pm
    HI Mike, Use Edit > Paste thumbnails
    Choose the poster frame you want to use and set it under the thumbnails tab, you’ll see a wee camera icon next to the right arrow.
    Go to your edit menu and copy the poster frame, or Cmd C on a Mac. Then select the required clips you wish to paste the new poster frame to, and go up to the edit menu once again and choose paste thumbnails.
    et voilá
    (Assuming you mean, paste the same poster frame to all clips)
    Stuart
    Sqareboxmedia
    CatDV / MME / Focalpoint /
