Activity Forums Adobe After Effects Set position of a solid using javascript without enabling a keyframe
  • Set position of a solid using javascript without enabling a keyframe
    Posted by George Matthew on December 12, 2008 at 3:46 pm
    How do I use javascript to set the position of a solid in a comp?
    I want to create a graph grid in a comp. Thought I could use javascript to easily modify the parameters of the grid than manually create it each time.
    Dan Ebberts site discusses about setValueAtTime() method for a layer property.
    But setValueAtTime() method adds a keyframe at the time given in its parameters.
    What method should I use to set the position of a solid in a comp without enabling a keyframe?
    Dan Ebberts
    replied 17 years, 9 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    December 12, 2008 at 4:18 pm
    If you’re using a script, you can just use setValue() to set a staic value with no keyframe.
    Dan
