Activity Forums Adobe Premiere Pro set duration for jpeg import
  • set duration for jpeg import
    Posted by Anhtu Vu on November 25, 2013 at 1:32 pm
    Is it possible so set the duration of my still prior to importing them ???
    I need to import thousands of stills with the duration of one frame, i believe PP default is at 5 sec….i hope there’s a way to change this in the preference. thx
    Walter Soyka replied 12 years, 9 months ago 3 Members · 2 Replies
  • Bob Glover
    November 25, 2013 at 1:42 pm
    In preferences there is General tab. Select Still Image Duration and change it to what you want.
    Good luck . Bob
  • Walter Soyka
    November 25, 2013 at 2:11 pm
    [Anhtu Vu] “Is it possible so set the duration of my still prior to importing them ???”
    Yes. Edit > Preferences > General > Still Image Default Duration. The default is 150 frames.
    However…
    [Anhtu Vu] “I need to import thousands of stills with the duration of one frame”
    Premiere also supports image sequences, so if you intend to cut your thousands of single-frame stills back to back, you might consider importing them as an image sequence instead so that you can treat them as a single clip.
    Walter Soyka
