Activity Forums Adobe After Effects Set “Create Proxy Movie” Output Default Settings? CS6
  • Set “Create Proxy Movie” Output Default Settings? CS6
    Posted by Claudiu Petrescu on March 18, 2014 at 10:24 pm
    Hello,
    I have around 100 folders of cinemaDNG sequences from blackmagic camera and I am using proxies in Premiere.
    Is there a way to set the default “CREATE PROXY-> MOVIE” settings so that I do not have to change the settings for each one of those proxies after i’ve created them?
    I managed to set the default output to h264 (instead of the default avi) but that’s about it.
    I also want to set:
    1. default resize to less than 2400×1350
    2. Profile to High instead of Normal
    3. Target Bitrate
    4. Maximum bitrate
    It’s such a pain to go one by one and change these 4 settings of each proxy…
    Ryan Dawson replied 12 years, 4 months ago 2 Members · 1 Reply
  • Ryan Dawson
    May 9, 2014 at 3:33 am
    Sounds like you are looking for a script. I myself am not a scripting expert, but I have found useful scripts online for the type of automation you are looking for.
