Activity › Forums › Adobe After Effects Expressions › Set an expression value to a layers name.
  • Set an expression value to a layers name.
    Posted by Lucas Malaquias on March 17, 2020 at 7:47 pm
    Hi, friends!
    I am looking a solution for a relatively simple problem, but I’m not sure if there is a solution.
    I am using a plugin called Templater. Using that plugin, I can change a layers name using a Google Sheet, for example.
    Because of that wanted to be able to change this expression by linking the “veloc” to another layers name.
    This is the expression
    veloc = 140;
    x = position[0] + (time – inPoint) *veloc;
    y = position[1];
    [x,y]
    Instead of “140” I wanted this value to be another layer’s name. That way, I can use the Templater plugin to change the name of the layer, and this will change the velocity that the text changes.
    That’s basically what I’m trying to achieve, if I change the layer name to 20, I want the expression to set its velocity to 20.
    Hope this is clear enough, thank you!
    veloc = 140;
    x = position[0] + (time - inPoint) *veloc;
    y = position[1];
    [x,y]
    Lucas Malaquias replied 6 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 17, 2020 at 11:05 pm
    Like this maybe:
    veloc = parseInt(thisComp.layer(1).name,10);
    y = position[1];
    [x,y]
    Dan
  • Lucas Malaquias
    March 17, 2020 at 11:44 pm
    Thank you, Dan! Worked like a charm.
    For other people that may end up with the same problem, I’ve also found that using the source text as a value works really well. Using this:
    veloc = parseInt(thisComp.layer(“layerName”).text.sourceText)
    x = position[0] + (time – inPoint) *veloc -300;
    y = position[1];
    [x,y]
    Thanks again, Dan! You’re the best.
