Activity › Forums › Adobe After Effects › Set a keyframe on every frame between 2 keyframes
  • Set a keyframe on every frame between 2 keyframes
    Posted by Isa Dimpfl on January 24, 2023 at 8:16 am
    hi,
    i made a curved animation path which a shape should follow. but when i am exporting it as an svg animation via bodymovin (lottie) the shape moves on a straight line.
    i assume that i can fix this problem by generating keyframes between those two keyframes, so the shape has a specific position on each frame.
    is there an easy solution to set a keyframe on every frame between 2 keyframes?
    thanks in advance!
    isa
    Isa Dimpfl replied 3 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 24, 2023 at 8:32 am
    You could run a little script like this:
    var comp = app.project.activeItem;
    var layer = comp.selectedLayers[0];
    var props = layer.selectedProperties;
    for (var i = 0; i < props.length; i++){
    if (props[i].canVaryOverTime && props[i].numKeys >= 2){
    var t1 = props[i].keyTime(1) + comp.frameDuration;
    var t2 = props[i].keyTime(2) - comp.frameDuration/2;
    var t = t1;
    while (t < t2){
    props[i].addKey(t);
    t+= comp.frameDuration;
  • Isa Dimpfl
    January 24, 2023 at 9:13 am
    thank you so much, i will give it a try.
    its surprising that there is not a built-in option in AE which does this for you – i don`t think that this is such an exotic demand..
