Activity Forums DaVinci Resolve session render behaves strangely and MEMEORY A-Z slots
  • session render behaves strangely and MEMEORY A-Z slots
    Posted by Andi Winter on February 22, 2011 at 10:14 am
    hi all!
    on my system the session – render menu behaves strange lately. i have to go to the menu several times until it pops up.
    is that a software bug or am i the only one experiencing this?
    and:
    i do have no davinci-panel and therefore can only access the memory slots A-H? am i interpreting this rightly? or is there any hidden shortcut or mouse-action which would let me access all the software-provided A-Z grade memory slots!?
    thx
    andy
    Dan Moran replied 15 years, 7 months ago 3 Members · 2 Replies
  • Margus Voll
    February 24, 2011 at 1:18 pm
    If i have woodo going on with session render then i restart my machine.
    It gives me always perfect results. I can not say why this happens as this machine has fcp
    and number of other things that run here so i can not say it is resolves fault
    or any other guys as i do not get is constantly and it is not something i can predict when it will happen.
    Maybe it is just that someone else keeps some memory reserved and voila
    i get error that i can not track.
    Just reboot you machine and see if it helps and let everybody know, then we could track this
    down.
    Margus
    https://iconstudios.eu
  • Dan Moran
    February 24, 2011 at 2:33 pm
    Hi Andy,
    Those shortcuts are mainly intended for the Resolve Control Surface as there is dedicated memory keys for all of those slots.
    You can use them if you need to by dragging grades into it and you can use the middle mouse button to load the grade from any still/memory or even another shot on the timeline.
    For the menu render you could try cmd R to bring it up ?
    I use that all the time and have had no issues with the Render page.
    Hope this helps!
    Dan Moran
    Application Specialist
    Blackmagic Design EMEA
