Activity › Forums › Adobe After Effects › Series of Images in one layer???
  • Series of Images in one layer???
    Posted by Alex Kuzelicki on April 4, 2006 at 8:24 am
    This is probably a really dumb question but… how do I import a series of images so that they all appear on one layer eg. a .TGA or .TIF sequence?
    I know I can put them into Final Cut and make them into a .MOV file and then bring them into After Effects but I want to preserve the Alpha Channel already made with the images.
    At the moment, when I try to import a series of images into After Effects I get a layer per image – which, with a long sequence, is way too unmanagable. Basically, I have some animated scenes created as .TGA sequences that I wish to composite (using their Alpha Channels) over some backgrounds.
    Hope this is not too dumb a question (I’m betting there’s a really simple answer). Thanks in advance.
    Regards,
    ALEX KUZELICKI
    Alex Kuzelicki replied 20 years, 6 months ago 3 Members · 3 Replies
  • Tim Kurkoski
    April 4, 2006 at 5:28 pm
    If your TGA files are numbered sequentially, AE can import them as an image sequence, which it will treat the same as a movie file. In the import dialog, choose the first file, then check the Numbered Sequence option in the lower-left.
    By the way, you can preserve your alpha channel with a QuickTime file. You have to use a codec that supports alpha, such as the Animation codec.
  • Michael Duff
    April 4, 2006 at 11:48 pm
    if they are not numbered I think there is a program called IrfanView or something like that which is free and does batch renaming/converson. It is a pretty funky little program for doing simple batch things.
    OR
    import all the files, stick them on the timeline and go “sequence layers” then precomp all these layers…..
    – hopefully they are numbered 🙂
    Michael Duff –
    Southern Cross Ten, Australia
  • Alex Kuzelicki
    April 5, 2006 at 3:39 am
    Thanks kindly, Timothy and Michael.
    Your help is much appreciated.
    Regards,
    ALEX
