Sequencing Layers Offset
Hi:
I was wondering if there was a way (or a script) to sequence layers so the time offset between them can increase or decrease?
For example, if I go to Keyframe Assist – Sequence Layers and set the overlap accordingly I can sequence my 10 layers with say a 20 frame gap between the start of each.
Is it possible to quickly apply a way to sequence the same layers but so that the duration of the gap decreases with each step – ie
Layer 2 comes in 20 frames after Layer 1
Layer 3 comes in 18 frames after Layer 2
Layer 4 comes in 16 frames after Layer 3
Layer 5 comes in 14 frames after Layer 4thank you
Nick
