Activity Forums Adobe After Effects sequencing layers and add an expression
  • sequencing layers and add an expression
    Posted by James Ander on March 25, 2008 at 5:22 pm
    Hi
    I have a question to anyone out there about sequencing layers. I have about 300 pics, I want them to be sequenced in layers and faded in, that part I know. now, I want every singe clips, as they fade in to scale up a little bit. I am pretty sure this could be solved by an expression.
    Jimmy
    Nate Hanson replied 18 years, 6 months ago 3 Members · 3 Replies
  • Darby Edelen
    March 25, 2008 at 6:51 pm
    [Jimmy Ahlander] ” now, I want every singe clips, as they fade in to scale up a little bit. I am pretty sure this could be solved by an expression. “
    You can link the opacity property to the scale property by applying an expression like this to the scale property:
    minO = 0; //Opacity when the scaling begins
    maxO = 100; //Opacity when the scaling finishes
    minS = 20; //Scale at minO
    maxS = 100; //Scale at maxO
    s = linear(opacity, minO, maxO, minS, maxS);
    [s,s]
    If you want the scale property to ease in/out of the scaling then you can replace linear above with ease, easeIn or easeOut.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • James Ander
    March 25, 2008 at 7:32 pm
    thank you so much for the tip, I’ll try it out.
    J
  • Nate Hanson
    March 25, 2008 at 10:11 pm
    Are you trying to make some kind of slide show? If you are, watch this tutorial:
    https://www.videocopilot.net/tutorials.html?id=48
    He shows you how to set up one photo (scale, adjustment layers, etc.) and then how to quickly apply the same effects/animations to all of your photos at the same time…sequenced in layers.
    Nate
