Activity Forums Apple Final Cut Pro Legacy sequences into multiclip
  • Shane Ross
    September 13, 2010 at 7:29 pm
    [mariana sussekind] “I am trying to create a multiclip sequence out of 5 sequences.
    Is It possible?”
    Nope. Multiclip only works with CLIPS. Not sequences.
    [mariana sussekind] “Cam I sync my 5 sequences into one multiclip? How?”
    Export them as self contained QT files, re-import them and use them as new source clips. WARNING, you will lose any and ALL reference to the source media. Meaning if you lose a drive, or want to revisit the cut…you might not be able too.
    Shane
