Sequence setup and export
I’m currently learning FCP from the ground up and plan on doing it the right way, but I need to get a project out the door immediately. So I’m hoping someone can give me some quick help in the hopes that I’ll learn a bit in the process.
I need to create some clips for uploading to YouTube/Vimeo.
My source files are all large AVI files. DV 720×480 (853×480), Millions 16-bit integer (Little Endian), Stereo, 48,000 kHz. FPS: 29.97. Data Rate: 30.31 Mbit/s.
I’ve got MPEG Streamclip ready to convert them to whatever i need. In fact, I’ve already done that once to get them into Apple Intermediate Codec to match my sequence in FCP. That works and it keeps me from having to render. But I can’t get the aspect ratio of the sequence to match the source files. The resulting clips are getting letterboxed. When I adjust the sequence after the fact, it requires re-rendering. I want to start over but thought I’d get some thoughts first so I dont waste more time.
So, what’s the best workflow/settings in this situation? I just want to output 16:9 clips in 720p for uploading to YT/Vimeo.
-r
