Activity Forums Apple Final Cut Pro Legacy Sequence Settings to export 720×640 H.264 Broadcast B-Roll
  • Sequence Settings to export 720×640 H.264 Broadcast B-Roll
    Posted by Mark Erickson on May 7, 2010 at 4:53 pm
    Howdy,
    I’m making B-Roll files of an event in the field for local broadcasters in SD: QT H264 720 x 480. Their specs. So I’m bringing my CPU/FCP/etc.. and importing HDV via firewire. OK so far.
    I need to shoot in HDV tape for later but I also need the field B-roll in SD. So I plan to drop the HDV footage into the timeline (sequence) set for SD: QT H264 720 x 480. I can “punch in” for 4:3. And I can export from the timeline as is.
    Waitaminute. 720 x 480 is wider than 640 x480 which is SD 4:3 aspect ratio.
    Why would they want 720 x 480? Is this a pixel aspect ratio adjustment?
    I need to give them something usable and I need to figure this out before the event next week.
    Your Thoughts?
    Mark Erickson replied 16 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
