Activity Forums Apple Final Cut Pro Legacy Sequence Settings & letterbox issues
  • Sequence Settings & letterbox issues
    Posted by Freddy Jones on May 20, 2009 at 3:45 pm
    After applying a Ripple Dissolve to a shot and noticing that it was bleeding the letterbox into the picture, I realized I might have a problem. Then I noticed my sequence settings have changed, not sure how, could really use some input.
    I shot video at 720p, 24pn.
    I originally set my sequence to the preset: HDV-720p24
    Pixel Aspect Ratio: Square
    Field Dominance: None
    Editing Timebase: 23.98
    QT Video Settings – Compressor: HDV 720p24
    Now, somehow, my sequence settings have changed to:
    720×480 – NTSC DV (3:2)
    Pixel Aspect Ratio: NTSC – CCIR 601/DV (720×480)
    Field Dominance: Lower
    Editing Timebase: 29.97
    QT Video Settings – Compressor: DV/DVCPRO-NTSC
    So were my original sequence settings proper?
    Should I change back to those settings?
    Can I change back to those settings?
    And how do I prevent this from happening again?
    Thanks so much.
    Freddy Jones replied 17 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
