Activity Forums Apple Final Cut Pro Legacy sequence settings in FCP give warped results in compressor
  • sequence settings in FCP give warped results in compressor
    Posted by Renan Ozturk on January 1, 2009 at 8:48 pm
    hi,
    my sequence setting for my 16 minute FCP movie are:
    frame size: 1440 x 1080
    aspect ratio: HD (1440×1080) (16:9)
    pixel aspect ratio: hd (1440×1080)
    field dominance: upper (odd)
    editing timebase: 29:97
    compressor hdv 1080i60
    Eventually I want to produce the highest quality DVD for film festival submission.. but at the moment I want to compress my edit into a smaller format to post on vimeo, to get some feedback on my work.
    I exported a non self contained quicktime movie from my FCP sequence then brought it into compressor and used the iphone apple setting. THe result was a warped movie!
    I know there is some easy formatting or setting answer. Thanks so much for helping!!
    cheers,
    renan
    Renan Ozturk replied 17 years, 8 months ago 3 Members · 4 Replies
  • Mike Barber
    January 1, 2009 at 11:18 pm
    Can you elaborate on what you mean by a “warped” movie? How many times did you try the iPhone preset? Was the result the same every time?
  • Renan Ozturk
    January 1, 2009 at 11:56 pm
    the image is stretched funny.. I tried the H.264 quicktime setting, the apple tv setting, and the iphone setting and they all look funny. I think it might be because of square vs nonsquare pixels??
    thanks for your help!
    ~renan
  • Rafael Amador
    January 2, 2009 at 2:53 am
    Hi Renan,
    Duplicate the preset and set the dimensions and Pixel aspect manually.
    Rafael
    http://www.nagavideo.com
  • Renan Ozturk
    January 3, 2009 at 4:18 am
    Thanks for your help, i’m still working on it and will let you know!
    cheers,
    ~renan
