Activity › Forums › Apple Final Cut Pro Legacy › sequence settings for XDCAM footage…
  • sequence settings for XDCAM footage…
    Posted by Zack Savitz on December 10, 2008 at 1:20 am
    Regarding workflow in FCP 6.0.5-
    Footage: XDCAM EX 1080p24 (35Mb/s VBR)
    Is it best to keep my sequence settings native to the footage or should I consider Apple Pro Res? Looking to maintain highest quality possible. With the “easy setup format” set to Sony XDCAM HD, “use” set to Custom, and “Rate” set to 23.98, my sequence settings are…
    Frame Size: 1920 x 1080 Aspect Ratio: HDTV 1080i (16:9)
    Pixel Aspect Ratio: Square
    Field Dominance: None
    Editing Timebase: 23.98
    QT Video Settings
    Compressor: XDCAM EX 1080p24
    If I was to go with Apple Pro Res, I would change the “Easy Setup Format” to Apple Pro Res 422, keep “Use” set to Custom, and change QT video compressor to Apple Pro Res 422 (HQ), correct?
    Ultimately, I want to make the best quality SD DVDs possible. Should this affect my choice for sequence settings or just my export settings? What should my export settings be?
    Thanks for the help!
    Lewis Lehmann replied 17 years, 7 months ago 4 Members · 5 Replies
  • Clinton Rocksmith
    December 10, 2008 at 3:59 am
    Hi there,
    Depending on how many effects and colour grading steps you may want to do there are plenty of options.
    I’m using a workflow with the EX format that goes like this:-
    – Using compressor convert all footage from XDCAM EX to ApplePro Res.
    – Edit those files and apply the effects
    – render and output with compressor to dvd
    Due to the long GOP of XDCAM EX, final rendering can take a REALLY long time. The projects I’m working on are 2 hours long mostly, so it’s always nice to get everything into the right format at the beginning to speed up the process of rendering at the end.
    This may or maynot be for you, but it’s something to think about.
    I also backup the original files from XDCAM onto various hard drives (which takes up minimal space) so that I always have the source material. And the project file.
    Cheers
  • Zack Savitz
    December 11, 2008 at 1:59 am
    Thanks for your response.
    I’m editing a music video that is under 4 minutes with little effects work and only a few video layers so rendering time should not be too much of an issue.
    In terms of quality, am I better off staying native or going to ApplePro Res?
  • Lewis Lehmann
    February 27, 2009 at 3:09 pm
    I’m going to reply to this thread before I start my own as this regards XDCam sequence settings issues in Final Cut pro.
    I’m trying to open already captured XDCam HD 1080p25 footage on my Mac Pro 3GHZ Quad Core Intel, with 5 GB RAM and a ATY RadeonX1900 video card.
    Here’s my problem, although the XDCam HD sequence settings are available in FCP, when I select them I get the old “codec not found. You may be running a compression type without the corresponding hardware card.” error.
    The strange thing is I can’t even open the XDcam clips, already captured off the card, in QuickTime either!
    Any idea what might be wrong? I have of course deleted my FCP prefs, but this didn’t help at all. I’m desperate for help.
    Lewis.
  • Andy Mees
    February 27, 2009 at 4:32 pm
    Lewis
    What version of FCP are you running there? You know, just to make life difficult there really are rather a lot of XDCAM HD codecs including the XDCAM EX strain which may be the footage you are working with. For that you need to be on FCP 6.0.3 or later …
    Best
    Andy
  • Lewis Lehmann
    February 28, 2009 at 9:19 am
    Hi Andy. I’m running 6.05. The strange thing is I’m running 6.0 on my Mac Book Pro, and the footage plays fine there! I’m also running an older version of Quicktime on the laptop! Should I attempt a re-install of FCP? Or will I just be compounding the issue?
