Activity › Forums › Apple Final Cut Pro Legacy › sequence settings for 720pn24 footage
  • sequence settings for 720pn24 footage
    Posted by Amy Wilson on November 2, 2007 at 8:19 pm
    I’m using 720pn24 footage from an HVX 200. I used the DVC Pro HD 720p24 easy setup (FCP v5.1.4) as was recommended by Apple. My sequence’s frame size, compressor, and pixel aspect match my clips and no rendering is required in my sequence, but the footage looks horizonally stretched. In trying to find the right settings, when I changed the pixel aspect to square, and the frame size to HDTV 720p, my picture looks perfect but my sequence needs rendering. Any ideas?
    Arnie Schlissel replied 18 years, 11 months ago 3 Members · 2 Replies
  • Michael Sacci
    November 2, 2007 at 9:56 pm
    where does your video looked stretched? external monitor? I know the clip and sequence for DVCProHD is 960×720 and for video out with my Kona 3 card you use 1280×720 setting but only for video out not the sequence or clips.
  • Arnie Schlissel
    November 3, 2007 at 1:49 am
    You should not use square pixels. DVCPro HD codecs all use anamorphic pixels. In your sequence & clip settings, there are pulldown boxes for pixel aspect ratio. Those should both be set to DVCPro HD 720. I can’t recall the exact wording, but I think you’ll find the right option!
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
