Activity Forums Adobe Premiere Pro Sequence Settings
  • Sequence Settings
    Posted by Frank Giardina on September 18, 2012 at 9:51 pm
    Hi…
    I’m new to CS6.
    1)There’s a Editing mode called DSLR for projects. Given I’m shooting with DSLR I’m guessing I should select that setting instead or 1920×1080?
    2)I touched on this one last week, so it’s kind of a followup. I imported some DSLR footage shot at 30fps into a 24fps timebase project. When I look at the frame Rate for the footage in the project bin it reads 23.976fps. Does that mean it was converted when I imported it??
    Frank Giardina
    17 Video Production
    Frank Giardina replied 13 years, 11 months ago 2 Members · 5 Replies
  • Chris Tompkins
    September 18, 2012 at 10:33 pm
    Those presets are for work styles and screen setup. Import your footage and drop a clip on the “Make a sequence icon” on the bottom of the project. It’ll match the clip for you.
    Chris Tompkins
    Video Atlanta LLC
  • Frank Giardina
    September 19, 2012 at 12:01 am
    Thanks Chris!!!
    Frank Giardina
    17 Video Production
  • Frank Giardina
    September 19, 2012 at 2:57 am
    Chris… I made a new sequence. Dropped the clip in and selected keep existing settings. With that being said, that clip should conform to 23.976. So, do I render then do a copy and paste or cut and paste into my project sequence with the actual 23.976 footage? I actually have 3 or 4 29.976 clips that I would like to use.
    Best Regards!!
    Frank Giardina
    17 Video Production
  • Chris Tompkins
    September 19, 2012 at 8:25 pm
    [Frank Giardina] “Dropped the clip in and selected keep existing settings”
    No, wrong answer.
    Let APP match the settings.
    You need to edit in a Sequence that matches your footage.
    Chris Tompkins
    Video Atlanta LLC
  • Frank Giardina
    September 19, 2012 at 9:00 pm
    OK, I’ll drop bring it into the sequence with my 24fps clips and let APP do it’s thing.
    Thanks Chris
    Frank Giardina
    17 Video Production
