Activity › Forums › Apple Final Cut Pro Legacy › Sequence Setting Recommendations
  • Sequence Setting Recommendations
    Posted by Jit Gohil on May 11, 2009 at 11:41 pm
    Hi All,
    I’m using Screenflow to record some screencasts of how to use a particular online application we’ve built. I’d like to not only edit it after exporting from Screenflow, but I’d like the option to play with it in Motion a little.
    So this leads me to my question.. both FCP and ScreenFlow provide a lot of customization when it comes to Output (in SF) and Input (in FCP). I’ve experimented a bit to see what the best setup might be between both.
    I’ll start by saying that the final output will be to the web at 960×540 30FPS, Progressive (Obviously) and 48kHz Audio. I’m basing that configuration on some of the Sequence Presets options I found in FCP.
    As far as the compressor goes, I’m using ProRes (HQ) at the moment and exporting a full 1080p (1920×1080) out of ScreenFlow. While I could reduce the exported size to match my FCP sequence preset of 960×540, I’d rather not, so I retain some ability to zoom the image (after export) without artifacts. This is because I want to ‘spice’ up some of the clips in Motion.
    My only qualm about the setup as it is, is that the file size for a 4 minute clip is about 4GB using ProRes! If I use a different compressor (e.g. Apple Animation) it is considerably smaller (about 400MB).
    So, based on this scenario and what I’m trying to do, can someone please make a recommendation of the settings I should use to both retain a great quality while keeping file sizes reasonable?
    Oh, also, after I’m done doing all the editing, I intend to export to FLV for easy web streaming. Though I’m open to suggestions on that as well (like quicktime?).
    Rafael Amador replied 17 years, 4 months ago 4 Members · 9 Replies
  • 9 Replies
  • Brian Cooney
    May 12, 2009 at 1:12 am
    I am presently doing something similar with Snapz for a ProTools and Logic Pro tutorial DVD. I have found that my capture clip dimensions 2560×1440 look superb if I scale down at the same ratio horizontally and vertically… for example.. 2560×1440 scaled down to 1920×1080 is the same ratio of 1.3 Width and height. 2560 to 1440 and 1920 to 1080. The minute i try to go down to 1440×1080 or 1280×720 where (W downscale is 1.7 and H is 1.3) it gets funky. This never happens with the video I down convert. But with the Snapz exports, every time. IT has been a real pain and trial and error to nail this down.. The Snapz exports do look a little better when taken into a ProRez sequence in FCP. But FCP’s animation compression setting and most others I tried only have remained true when the vertical and horizontal down-scaling was done at the same ratio.
  • David Roth weiss
    May 12, 2009 at 1:46 am
    Jit,
    There’s no reason to use ProRes HQ, just use ProRes.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • David Roth weiss
    May 12, 2009 at 1:57 am
    [Brian Cooney] “The minute i try to go down to 1440×1080 or 1280×720 where (W downscale is 1.7 and H is 1.3) it gets funky.”
    1440×1080 is a squeezed anamorphic pixel dimension for HDV or DVCProHD camera original that unsqueeezes to display at 1920×1080. You shouldn’t be scaling down to the anamorphic dimensions. 1920×1080 is full raster 1080i or 1080p, just use that.
    Why you’re having an issue scaling to full raster 720p, which is 1280×720, I have no idea. But, if you stick with 1920×1080 you’ll be fine.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jit Gohil
    May 12, 2009 at 2:10 am
    Hi Brian,
    Perhaps my inexperience will show in my next question.. But how did you get 1920×1080 as 1.3 Aspect Ratio? When I do the math 1920/1080 it comes out to 1.7 Am I missing something important in the aspect ratio determination?
    Now that you mention it, I’ve always been a bit confused about setting the aspect ratio of a sequence in FCP. Why is it that I have an option to select an aspect ratio, but then given another option to select ‘Anamorphic 16×9’? Does that override the dropdown Aspect Ratio selection? And finally, when I’ve selected either of those (or both) – what does that do to the ‘Correct for Aspect Ratio’ setting in the viewer?
    Also, in this case, I did intend to scale my sequence down proportionately from 1920×1080 into 960×540
    I guess more at the heart of my question is which compressor to use for the best balance between quality and file size.
  • Jit Gohil
    May 12, 2009 at 2:13 am
    Hi David,
    Thanks for the tip! Is that because there is no noticeable difference in quality, while maintaining a smaller file size? Or is it just a best practice for footage destined for the web?
  • Brian Cooney
    May 12, 2009 at 3:50 am
    Hi Jit, maybe I was confusing. what I meant to say was i divided the present width by the desired width and got 1.3 then did the same with the height and got 1.3 so width 2560 divided by new downsized width 1920 equals 1.3 and height 1440 divided by new downsized height 1080 equals 1.3…….Whereas for example width 2560 divided by width 1440 equals 1.7 and height 1440 divided by height 1080 equals 1.3 creating different scaling. So the point being there is an irregular conversion which the capture export seems to be unable to hold up under. 🙂
  • Rafael Amador
    May 12, 2009 at 3:51 am
    Hi Jit,
    Forget about “Anamorphic”. You are using SQUARE PIXELS.
    Forget 1.7 or 1.3. talk about 16×9 or 4×3.
    1920/16 = 120
    1080/9 = 120
    Or;
    1280/16 = 80
    720/9 = 80
    Just take any number ad multiply for 16 to get the width, and multiply it by 9 to get the high.
    Yes the realtion will be 16/9 = 1.7
    The same happens when working in 4×3 WITH SQUARE PIXELS.
    Multiplay a certain number by 4 and by 3 to get width and high.
    The relation will be 4/3 = 1.3
    rafael
    http://www.nagavideo.com
  • Brian Cooney
    May 12, 2009 at 3:58 am
    Hi Jit, maybe I was confusing. what I meant to say was i divided the present width by the desired width and got 1.3 then did the same with the height and got 1.3 so width 2560 divided by new downsized width 1920 equals 1.3 and height 1440 divided by new downsized height 1080 equals 1.3…….Whereas for example width 2560 divided by width 1440 equals 1.7 and height 1440 divided by height 1080 equals 1.3 creating different scaling. So the point being there is an irregular conversion which the capture software seems to be unable to hold up under. 🙂
  • Rafael Amador
    May 12, 2009 at 4:02 am
    [Brian Cooney] “So the point being there is an irregular conversion which the capture export seems to be unable to hold up under. :)”
    No.
    What you have to think is that 1440×1080 formats use a different kind of pixels (HD) than formats working 1920×1080 (Squared).
    rafael
