Activity Forums Apple Final Cut Pro Legacy Sequence set to non-drop… but it is still drop frame!
  • Sequence set to non-drop… but it is still drop frame!
    Posted by Bill Russell on September 9, 2010 at 1:57 am
    Okay, I’m having a super annoying problem. I’ve got a sequence, its set to non-drop frame. But… after months of working on it, I just discovered that the timecode count is non-drop! (skipping count :00 and :01 ever two minutes, as drop frame does.) I’ve tried switching it to drop then back to non-drop, but no fix. My other sequences appear fine (some drop, some non-drop). I REALLY don’t want to have to create a new sequence and render this all out again.
    I’ve already trashed preferences. Anybody ever have this problem?
    John Pale replied 16 years ago 2 Members · 2 Replies
  • Bill Russell
    September 9, 2010 at 2:02 am
    Doh! Nevermind. If you right-click in the timecode box, you can check / uncheck “drop-frame” (or “non-drop”, depending on what your sequence is set at). Must be new… and I can’t fathom what use this is. Oh well.
    “THE LOST SKELETON OF CADAVRA”
    And more…
  • John Pale
    September 9, 2010 at 2:04 am
    What happens if you create a new empty sequence non-drop frame, then copy/paste everything into it?
