Activity Forums Apple Final Cut Pro Legacy sequence problem
  • sequence problem
    Posted by Laurent Dupepe on August 15, 2008 at 4:48 pm
    I have a sequence that has, all of a sudden, gone to 4:3. Is there a way to re-link the clips of my sequence to the master clips so that the clips in the sequence reverts back to it true size? It’s the only sequence in the project that all the clips in it are square.
    Correct for aspect ratio is selected. For some odd reason the entire sequence has this look to it.
    Laurent
    Rafael Amador replied 18 years, 1 month ago 2 Members · 1 Reply
  • Rafael Amador
    August 16, 2008 at 1:36 am
    [Laurent Dupepe] ” It’s the only sequence in the project that all the clips in it are square. “
    In the other thread you said that you were working in DVCPro HD. Your sequence must have DVCPro HD pixels, no square. Try to change it in the Sequence setting.
    Rafael
    http://www.nagavideo.com
