sequence presets and capture presets for mini-dv
Please help with my settings for the best quality for importing and exporting quicktime movies mostly for dvd use (idvd for now…)
I want to use “none” as compressor for capturing, but the files end up way too large (i only have 60 G), i end up using NTSV/DV 100 quality
For sequence presets, i then match it up here as NTSC/DV but am unsure about the “field dominance”
when i export based on preset above, i THEN export as “none” compressor at 100% file is bit large but doable
thanks for the help always gurus……(and shane – thanks for the help on my most recent codec issue – you SAVED my project. can’t believe i never knew how to use the auto save vault!)
olivia
