Activity Forums VEGAS Pro Sequence of Still Images — Batch Process?
  • Sequence of Still Images — Batch Process?
    Posted by Devon Thomas treadwell on August 2, 2014 at 3:41 am
    I’m using Sony Vegas 12.0. I have a time sequence that was shot by a still camera, the images saved as jpgs. I’d like to cut these shots together in rapid sequence–maybe even one shot per frame. Is there a way to batch these onto the timeline, putting them in alphabetical order and specifying the default duration of the clip? What I’d like to do is import the media, then drag and drop the jpgs onto the timeline and have the images appear in sequence on a single video track.
    Doable?
    Steve Rhoden replied 12 years, 1 month ago 3 Members · 5 Replies
  • Norman Black
    August 2, 2014 at 4:50 am
    If the stills are sequentially numbered you can import them as an image sequence. Vegas treats each still as a frame of an effective video file. The project media will list the sequence as a single media file you can drop on the timeline. On import you specify the frame rate of the image sequence. Remember that you are not limited by the frame rates listed in the drop down list Vegas shows you. You can enter what you want.
    Another way is to set your edit preferences for the default still image event length, and drop a bunch of stills on the timeline. Vegas will drop them sequentially as selected at the length you specified in prefs. You will get one event per still.
  • Steve Rhoden
    August 2, 2014 at 11:25 am
    Doable yes. Norman covered all the bases for you.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Devon Thomas treadwell
    August 2, 2014 at 12:53 pm
    Thanks, that’s what I was hoping for!
    August 2, 2014 at 3:38 pm
    Well, this is bizarre. When I try to import a batch of jpgs and select all, I’m getting an error that half the files are not found. When I click on each file individually, the Open Sequence checkbox is greyed out on every other file. What could that mean?
  • Steve Rhoden
    August 2, 2014 at 7:31 pm
    No, simply hover the cursor over the first image in the sequence
    until it’s highlighted, then select the Open Sequence box and then
    press Open.
