Activity Forums Maxon Cinema 4D Sequence of bitmaps as texture in Cinema 4D
  • Sequence of bitmaps as texture in Cinema 4D
    Posted by Pegasusii on July 31, 2006 at 6:57 pm
    Hi! Does anyone know how i can use a sequence of bitmaps as a texture… I have a sequence of images produced by RealFlow and i want to use them as a mask in a water material that i already have… Any idea??
    I am a little newbie in these stuff so please be patient!…
    Thanks a lot
    Pegasusii replied 20 years, 1 month ago 3 Members · 3 Replies
  • Nolan Scott
    July 31, 2006 at 11:37 pm
    If you have 9.6 – in the texture colour channel import the first image of your sequence,
    click the edit button and select the animation tab – click calculate.
    Cheers
    Nolan
  • Björn Marl
    August 1, 2006 at 6:12 am
    9.6 is only needed if you want to be able to preview this in the editor, at rendertime this works since at least since release 5 if i’m not mistaken.
    Cheers
    Bj
  • Pegasusii
    August 1, 2006 at 8:42 am
    You ‘re right my friend, thank you!! But…
    (That’s my fault) I believed that with this knowledge i could understand what i had to do…
    My tries are about making a boat to “cut the ocean effect”. So i used RealFlow and i run out the tutorial that exists in User-Guide https://www.nextlimit.com/realflow/userg/user_guide.pdf …This process exports a sd file and a sequence of tga files that includes the foam. And the tutorial says:
    “When you give texture to the sea, use the sequence foam.tga as a mask to create the
    effect of the wake, using a more off-white material than the water. The foam sequence is
    in the project folder, in folder images.
    All platforms can use a sequence of bitmaps as a texture […]”
    So, i have to make this sequence, mask to my other material(water)… Is this possible ??
    Now, i talk clearly!! 😉
