Activity Forums Adobe After Effects Sequence numbers after file extension?
  • Sequence numbers after file extension?
    Posted by Brad Graber on December 7, 2016 at 2:50 pm
    Hey guys,
    Is there a way to render out a .jpg sequence that has the numbers after the file extension? So it would be: ‘Sandwich.jpg.120’….
    BG
    Daniel Waldron replied 9 years, 8 months ago 3 Members · 3 Replies
  • Roei Tzoref
    December 7, 2016 at 4:21 pm
    export your sequence as usual and something like this with bridge batch rename other batch rename software
    couldn’t find how to put a period between the jpg and the number…
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Brad Graber
    December 7, 2016 at 6:42 pm
    Thanks for your replies. I’m on a Mac, and I’m trying to import footage into Maya. Maya won’t read the jpg sequence with the extension at the end. I’ll try the batch converter you mentioned.
    BG
  • Daniel Waldron
    December 7, 2016 at 8:54 pm
    On a Mac you can use Automater to batch rename your files.
