Activity › Forums › Adobe Premiere Pro › sequence needing render but why ?
  • sequence needing render but why ?
    Posted by Alexandre Brandt on July 28, 2013 at 4:55 pm
    Hello,
    I have two long clips of about 45 min each in a sequence (concert recording). Its HDV 1080p25 codec in a mov file. The sequence is set the same settings however the red line for render is there. When I play back at 1/2 or a full res the playback lags. I’m wondering why is that so. Maybe something in my settings I’m doing wrong ?
    Thanks for the attention !
    motion pictures + storytelling = ?
    -> FILMMAKING !
    Alexandre Brandt replied 13 years, 2 months ago 2 Members · 2 Replies
  • Ann Bens
    July 28, 2013 at 5:16 pm
    Red line usually means you settings do not match your footage.
    For correct sequence settings drag a clip from the project panel into the new item icon at the bottom of the panel.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Alexandre Brandt
    July 29, 2013 at 8:24 am
    Ok, thank you !
    -> FILMMAKING !
