Activity › Forums › Apple Final Cut Pro Legacy › Sequence Merging
  • Sequence Merging
    Posted by Jason Goodson on August 16, 2010 at 6:46 am
    Hey Everyone. I’ve got a question I was hoping someone might be able to help me with. Basically, I have a 90min sporting event that I need to breakdown. I’m doing the first hour and another assistant is doing the second hour on another machine.
    Question: With the 20 Sequences that we tag for, being named the same on both machines, what is the best way to import his 2nd hour sequences from his MacBookPro, to the 1st hour sequences on my MacPro once we’re both finished. I need to insert his “tagged moments” to the end of mine, so that I can send them to Compressor in order to upload on-line.
    I hope I’ve explained the scenario well enough, and thanks to those taking the time to help, as it’s much appreciated!
    Aloha – Jason
    Aloha – Jason
    Jason Goodson replied 16 years, 1 month ago 2 Members · 2 Replies
  • Tom Wolsky
    August 16, 2010 at 11:16 am
    If you have the media that the other editor is working with, copy the project file to your machine, and then copy the sequences from his project to your project. Render and mixdown all the sequences. Put all the sequences one after the other in a final sequence. Render and mixdown and output.
    If you don’t have the media, the other editor should export a self-contained QuickTime Movie for you to import.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Jason Goodson
    August 16, 2010 at 10:00 pm
    Thanks Tom! I’m trying it now. Cheers!
    Aloha – Jason
