Activity Forums Apple Final Cut Pro Legacy Sequence jumps during play back after rendering & locks up when exporting QT
  • Sequence jumps during play back after rendering & locks up when exporting QT
    Posted by Sean Harris on May 18, 2006 at 1:34 pm
    My 28:30 minute infomercial jumps during play back (a quick, but noticeable horizontal shift of video). I have rendered and rendered Mix down only. When I try to export to QT the dreaded beach ball comes after about 10 minutes.
    Any suggestions? I have switched graphic cards to accomodate Motion, and I am working with a KONA SD card. Generally speaking the switch of graphic card did seem to slow performance, but I just don’t know what to do right now to get this infomercial out the door.
    Sean Harris replied 20 years, 4 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 18, 2006 at 3:28 pm
    Might trash your render files around the area that isn’t playing back well… then re-render.
    Jerry
  • Sean Harris
    May 18, 2006 at 3:46 pm
    Thanks for the suggestion.
    I did have a sequence inside the sequence. As a hunch, I removed the sequence and replaced it a copy of all the files in the sequence. After doing that, FCP finally worked through a complete QT export (without lockup) which I used to created a new sequence, and laid to BetaSP. Whew!
    The only problem is, that before and not that long ago, I could do a render and mixdown-only render, then lay to tape no problem. It seems like now, I always have to make a QT then lay to tape. Is that normal? Any suggestion would be appreciated.
    Thanks again.
    Sean
