Activity › Forums › Apple Final Cut Pro Legacy › Sequence forcing image to 4:3
  • Sequence forcing image to 4:3
    Posted by Lars Sigsgaard berg on August 5, 2010 at 12:02 pm
    Found myself in bit of a trouble here after loading hd material shot from a cannon 5D (25fps) and a 550d(25fps aswell).
    The 5D material appears fine but whenever i add clips from the 550d to the timeline, the sequence forces the 550d clip to 4:3 aspect ratio.
    All the material is compressed to proress 422 with this sequence setup:
    1920×1080 HDTV1080i(16:9)
    Pixel Aspect Ratio: Square
    Field Dominance: Upper (Odd)
    Compressor: Apple Proress 422
    Have anyone experienced this before/have a solution for it? 🙂
    John Fishback replied 16 years, 2 months ago 2 Members · 1 Reply
  • John Fishback
    August 5, 2010 at 5:12 pm
    I’ve not worked with either camera’s media, but check the clip’s Item Properties in the Browser and see if the Anamorphic box is checked. If not, try checking it.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
