Activity Forums Square Box CatDV sequence clips list by seq. time – error message
  • sequence clips list by seq. time – error message
    Posted by Carsten Orlt on January 26, 2010 at 6:06 am
    I’m just trying the demo version and are very close to get a licence BUT one big problem:
    What I will need quite often is to export a FCP seq via XML and create a text list of the used clips by sequence timecode.
    Now I can import the XML into CatDV without problems but then I get the following error when I try to display clips by seq. TC:
    “Failed to select clip (java.lang.NullLPointerException)”
    Anybody knows what that means?
    Cheers
    Carsten
    Rolf Howarth replied 16 years, 7 months ago 2 Members · 2 Replies
  • Carsten Orlt
    January 26, 2010 at 6:48 am
    Addition:
    I now figured out that it can only be a bug in CatDV.
    When I select to list ‘source clips’ from the seq. all clips are fine.
    When I look at ‘All clips’ the first 2 clips from the seq. are not showing correctly (they can’t correctly link to the media)
    I checked FCP seq and XML file and they look fine (no super expert so I might have overlooked something).
    Anybody else having problem with this functionality?
    Cheers
    Carsten
    Carsten
  • Rolf Howarth
    January 26, 2010 at 9:13 am
    Yes, that sounds like a bug. Can you mail the XML file you are using to support@squarebox.co.uk so we can investigate please?
