Activity Forums Maxon Cinema 4D Seperate AO pass for objects enclosed by a glass container?
  • Seperate AO pass for objects enclosed by a glass container?
    Posted by Manojit Ghose on June 8, 2017 at 11:57 am
    Is there a way get a separate A.O. pass for objects enclosed inside a glass container in C4d? (ofcourse without having to render it twice)
    i am using the physical renderer.
    m.
    MG
    Brian Jones replied 9 years, 3 months ago 2 Members · 4 Replies
  • Brian Jones
    June 9, 2017 at 10:07 pm
    probably not but why?
  • Manojit Ghose
    June 10, 2017 at 12:25 am
    i need to render a clear plastic container with pills in in it. and then composite it in different multiple backgrounds (of different colors), and i should be able to see the background through the pack.
    thanks
    m.
    MG
  • Manojit Ghose
    June 10, 2017 at 12:27 am
    i need to render a clear plastic container with pills in in it. and then able to control the AO of the pills as well in post.
    thanks
    m.
    MG
  • Brian Jones
    June 10, 2017 at 1:01 am
    Hmm I assume you have AO turned off for the glass…. just thinking out loud… since all the pills are in the glass container you could give that an Object buffer and use that to isolate the AO of the pills (maybe – assuming there not too much behind the glass
