separate audio syncs when captured in real time – not when directly imported
Shot a 2 hour program with a card based camera and recorded the audio separately through the house sound system with a little tascam DR40.
When I directly copied and imported the .wav file from the DR40 to FCP, the audio sync drifts relative to the camera footage about 2 frames every 10 minutes.
But if I go to the trouble of playing the dr40 in real time and capturing its analog output into FCP – even with no video reference, everything stays in perfect sync.
Now, I don’t want to spend the time or have a crappy analog signal in my edit so I’m wondering if there’s a way to take that .wav file and apply some sort of time compression/expansion.
I know this has got to be some classic ratio between audio and video systems.
Thanks for any suggestions!
