Activity › Forums › Audio › Sennheiser sk 500 Line in
  • Sennheiser sk 500 Line in
    Posted by Frank Smith on September 26, 2011 at 6:36 pm
    OK… I have Sennheiser wireless transmitters and receivers (500 series). The transmitter says that it can take a mic or line input. When I connect an xlr to 1/8″ cable that I normally use to connect a mic to the transmitter… it is way over modulated. Is there a different wiring scheme for an xlr/line in cable? Or… just what IS the deal? Do I need to turn the sensitivity way down instead, or what?
    I very rarely need to take a feed from an event audio board… and when I do, I can usually get a mic level out. In rare circumstances I have to use a line level out… and then I usually just use a cable, but sometimes I need the camera to be more mobile, so I need to understand what I need to do differently to make my wireless system perform properly with a line level input.
    Thanks in advance.
    Frank Smith
    Franklin Video, Inc.
    Frank@FranklinVideo.com
    http://www.FranklinVideo.com
    Frank Smith replied 15 years ago 2 Members · 2 Replies
  • Eric Toline
    September 26, 2011 at 7:06 pm
    For line in you need to connect the source audio to the ring not the tip. Tip is for mic level, ring for line level.
    Eric
  • Frank Smith
    September 26, 2011 at 8:12 pm
    THAT works! I just made a couple of those out of a couple of extra mic level cables… Now, I probably wont need one for a few years… but I have them! Thanks for the info.
    Frank Smith
