Activity Forums Audio Sennheiser EW100 Mic repair?
  • Sennheiser EW100 Mic repair?
    Posted by Jeremy Wiles on March 6, 2007 at 10:10 pm
    Does anyone know how to repair or replace the rubber casing that encases the antenna on the Sennheiser EW100 wireless mics? I accidently shut the antenna in the protective case I keep it in and it ripped off the rubber casing around the antenna. Now I seem to get some occassional stactic from the mics.
    Jeremy
    Jeremy Wiles replied 19 years, 6 months ago 2 Members · 2 Replies
  • Will Salley
    March 7, 2007 at 4:23 am
    Try 1/8 or 3/16 inch shrink wrap. The rubber is just there for protection, it doesn’t really affect the operation of the antenna (unless it gets wet). I’ve got few in which the rubber is completely gone and they work fine, they just look bad. Just make sure the wire itself is not damaged.
    System Info – G5/Dual 2 – 10.4.8 – QT v7.1.3 – 8GB ram – Radeon 9800Pro – External SATA Raid – Decklink Extreme – Wacom 6×8
  • Jeremy Wiles
    March 14, 2007 at 4:44 pm
    Do you think if I put some gaffer tape around it that it would affect the reception?
