Activity › Forums › Audio › sennheiser ew100 g2 – bad results
  • sennheiser ew100 g2 – bad results
    Posted by Phil Sheldon on December 23, 2011 at 12:01 pm
    i got the above clip mic system a few years ago and have never got good results from it. the recording has always been distorted and scratchy.
    consequently it was put away and has been gathering dust, but i potentially need it working properly in the new year.
    i had tried resetting everything but no difference, so was wondering if anyone else has had issues with these.
    all the cables look fine but could it be worth trying to replace the mic
    any suggestions gratefully recieved
    merry christmas!
    Phil
    John Fishback replied 14 years, 8 months ago 3 Members · 3 Replies
  • Ty Ford
    December 23, 2011 at 2:01 pm
    Hello Phil and welcome to the Cow Audio Forum.
    The Sennheiser G2 is an entry level workhorse. Proper use does require some knowledge. Mic sensitivity settings, receiver level settings, frequency settings, lav placement, all come into play. In effect, you are operating a miniature radio station.
    Perhaps you could post a link to a section of problem audio.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
  • Phil Sheldon
    January 4, 2012 at 1:33 pm
    hi there Ty
    thanks for replying. works been closed over christmas so have only just got back to this.
    i’ll get the units up and running and get some audio recorded as soon as possible
    cheers for now
    Phil
  • John Fishback
    January 12, 2012 at 9:50 pm
    Somewhere on Sennheiser’s site is a way to check your area for interference on the freqs your mic uses.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
