Activity › Forums › Audio › Sennheiser EW 100 G2
  • Sennheiser EW 100 G2
    Posted by Alexandra Kharazyan on November 2, 2011 at 2:29 pm
    Hello!
    I’ve been using the Sennheiser wireless systems for a long time with no problems at all, they always work and sound great, but now I am having an issue with my EW 100. The settings on the transmitter and the receiver looks correct (the sensitivity and AF out set as always, squelch is low), the AF and RF are OK, but there’s no sound coming out from the receiver (tried both XLR and jack). What could be the problem and how could I fix it? Thank you!
    Steven Peer replied 14 years, 6 months ago 6 Members · 7 Replies
  • 7 Replies
  • Noah Kadner
    November 2, 2011 at 4:14 pm
    Perhaps it needs repair?
    Noah
    Call Box Training.
    Featuring the Panasonic GH2 and GoPro HD Hero.
  • Alexandra Kharazyan
    November 2, 2011 at 4:20 pm
    Obviously. It’s the most trivial answer. But I’m looking for an advise which could help me fix it by myself.
  • David C jones
    November 2, 2011 at 4:36 pm
    Perhaps the “mute” function is engaged. Or something on the camera was accidentally switched.
    Dave J
  • Peter Groom
    November 2, 2011 at 4:43 pm
    try tuning to a new freq and back again. Mine got twisted that way once.
    Peter
    Post Production Dubbing Mixer
    November 2, 2011 at 4:47 pm
    2David Jones: no, it’s not muted.
    2Peter Groom: thanks, I’ll try to do so!
  • Eric Toline
    November 2, 2011 at 7:50 pm
    Try a different cable from the receiver. If you have the original 3.5mm TRS to XLR-M that came with the set, that most likely is the problem. With those Sennheiser supplied cables it’s not a matter if they’ll fail it’s when they’ll fail and they always fail and they can’t be repaired as they’re molded on connectors.
    Eric
  • Steven Peer
    April 1, 2012 at 11:28 pm
    Eric, thanks for the head’s up. Indeed, I inherited a EW100 set with two failed cables. Do you have a 3rd party source you use? Or, if I build one, I note that it is 3.5mm female stereo – to – 6.3mm (1/4″) male phono mono. What is the wiring — does one use the Left, Right, or Both sides of the 3.5mm stereo? Thanks.
