Activity Forums Apple Final Cut Pro Legacy Sending out a cut list with handles
  • Sending out a cut list with handles
    Posted by Don Ortega on October 22, 2007 at 5:43 pm
    I’m on FCS 2 and I’ve got a feature here that I’m trying to send to the neg cutter. The neg cutter is requesting that I give him 32 frames handles on the cut list. How do I do that? I enter 32 frames into the handle length in the export cut list dialog box, but every time I export the cut list, I only get the exact length of the shot without any handles. This occurs in both the cut AND the pull lists. How do I get handles, the neg cutter won’t start until he gets handles.
    Dan
    Alexandre Chartrand replied 17 years, 11 months ago 3 Members · 4 Replies
  • Steven Gonzales
    October 22, 2007 at 7:59 pm
    One way to get 32 frame handles on each cut would be to place a 32 frame transition at each cut, just for the sake of the lists.
    Otherwise, I thought Cinema Tools only allowed up to 5-1/2 frames for cut handles.
  • Steven Gonzales
    October 22, 2007 at 8:05 pm
    Actually, to get 32 frames on each side you would need a 64 frame transition.
  • Don Ortega
    October 22, 2007 at 8:08 pm
    Thanks, I’ll keep looking for an easier solution, but if it turns out I have to, I’ll go with your suggestion.
  • Alexandre Chartrand
    October 14, 2008 at 9:04 pm
    Hi Dan !
    I see it’s been a year or so since you’ve asked the Handle size question on this forum. I’m having the exact same problem now. I’m finishing the editing of a feature documentary on FCP, and I need to go threw a DI process in order to print the final film copy. The neg cutter is asking for a 30 frame handle on each cut, and Cinema Tools only offers a maximum of 5 1/2 frame handle.
    How did you solve your problem ?
    I thank you deeply !
    Alex
