Activity › Forums › Apple Final Cut Pro › Sending Multicam Window out to Client Monitor
  • Sending Multicam Window out to Client Monitor
    Posted by Jordan Mena on September 27, 2013 at 7:58 pm
    Is there a way to send the multicam window (with all the angles) out to my client monitor? My producer likes to see all the angles on our client monitor while he’s watching the show to see if he likes another angle better on any given shot. I could do this in FCP7. I wonder if it’s possible in X.
    Thanks, j
    Jordan Mena | Editor | Colorist | Producer
    Los Angeles, CA
    jordanmena.com
    T. Payton replied 12 years, 12 months ago 3 Members · 2 Replies
  • James Cude
    September 27, 2013 at 10:44 pm
    FCPX itself can’t do that but you could probably rig up something with mirroring and HDMI out- depending on your hardware.
  • T. Payton
    October 4, 2013 at 8:04 pm
    i’ve got a 2012 iMac, 30″ Cinema display and then I use the Matrox MX02 to feed a 47″ LCD via HDMI and a 15 CRT via s-video.
    However, I picked up a mini display port to VGA (works better than HDMI for my LCD) and then I’ll just plug it in and then mirror my second display to it. To do this, option drag one monitor to the other in Display Preferences Arrange, once you set it anytime you plug in that third monitor it will automatically switch your settings back to your mirrored settings.
    Works great.
    T. Payton
    OneCreative, Albuquerque
