Activity Forums Apple Final Cut Pro Legacy Sending HD to SD-DVD in FCP
  • Sending HD to SD-DVD in FCP
    Posted by Channup on April 30, 2006 at 3:24 am
    I have been editing in Final Cut Pro Studio in Panasonic’s DVCPro HD codec (720p). I am trying to go to SD-DVD. When I export using compressor, and watch it on a TV, the higher resolution of HD seems to create a vibration on the finer detailed lines.
    Is there a standard for compressing HD to SD-DVD? I’ve tried my finished putting my project in a DV NTSC timeline and re-rendering it. But that seems a bit counter productive and defeating the point of HD. But then again, I guess putting HD to SD-DVD defeats the purpose as well. But I’m stuck doing it for the time.
    Any suggestions???
    Channing Lowe
    Channup replied 20 years, 4 months ago 3 Members · 6 Replies
  • Wes Plate
    April 30, 2006 at 3:28 am
    I was going to make the same point you came around to.
    I wonder if something like a slight blur would help your fine shimmering lines.
    — Wes Plate
    Automatic Duck
  • Matt Sandström
    May 1, 2006 at 11:03 am
    turn on frame controls in compressor.
    /matt
    https://www.mattias.nu/
  • Channup
    May 2, 2006 at 12:23 am
    I found where the frame controls are. Do you just put it on Automatic, or is there a specific custom way to do it? I don’t see anywhere to toggle it on and off.
  • Matt Sandström
    May 2, 2006 at 7:38 am
    off is off. manual and automatic is on. setting it to automatic should work. otherwise manual with scaling set to highest quality will do the trick.
    /matt
  • Matt Sandström
    May 2, 2006 at 7:39 am
    or is that “custom”? i don’t have compressor on this computer.
    /matt
  • Channup
    May 3, 2006 at 7:05 am
    That worked great.
    Thanks.
