Activity Forums Apple Final Cut Pro Legacy send to STP problems
  • send to STP problems
    Posted by Sesammedia on November 13, 2007 at 8:06 am
    hi
    I have used final cut for a long time and just started using STP (v2)
    I want to use send to STP multitrack project in FCP. when I do this everything seems fine but in STP the levels are wrong, most of them are at zero. The fades doesnt work, I can se them but they act like a cut. even when I send to STP multitrackproject without fades and make the fades in STP, I cant hear them and the levels are off.
    I want to be able to edit in FCP and roughly mix the audio and then send to STP and make the final mix there. I guess this is what STP is for, right?
    Sesammedia replied 18 years, 9 months ago 1 Member · 1 Reply
  • Sesammedia
    November 17, 2007 at 10:28 am
    Is this a problem that cant be solved? you are very quiet guys.
