Activity Forums Apple Final Cut Pro Legacy “Send To Shake” option missing
  • “Send To Shake” option missing
    Posted by Keicol on September 15, 2006 at 7:37 am
    I just configured a new Intel mac 3 gHz machine with Shake 4.1 then Final Cut Pro 5.1.
    I thought I should install Shake first for no reason other than it sounded good at the time. The “send to Shake” option isn’t highlighted as a viable option inside Final Cut, is there a trick I’m missing to turn that option on or could I have installed it in the wrong order?
    Thanks, Keith
    Shane Ross replied 20 years ago 2 Members · 1 Reply
  • Shane Ross
    September 15, 2006 at 8:44 am
    YOu highlighted the clip(s) you wanted and then chose FILE>SEND TO>SHAKE. You have to highlight your clips first.
    Shane
    Littlefrog Post
    http://www.lfhd.net
