Activity › Forums › Apple Motion › “Send to Motion” from FCP give Low-res Footage
Posted by Erik Lindahl on April 11, 2006 at 1:26 pmSorry if this is concidered a double post, but it really is a Final Cut AND/OR Motion issue
Erik Lindahl replied 20 years, 5 months ago 3 Members · 5 Replies -
Doyle Rockwell
April 11, 2006 at 5:08 pmHey Erik,
When FCP sends the footage to Motion, it creates a Motion project with the footage already imported. I would hazard that FCP is not properly setting the Alpha Type for the clip, in the Motion project. But when you import it into Motion, yourself, Motion has the opportunity to detect/guess the alpha, and sets it correctly.
If it seems like the alpha is gone, just select the clip (in Motion) and press Shift+F, which will take you to the Media settings for that footage. Check the Alpha Type popup menu (first item) in the Media tab of the Inspector, and see if making a change fixes your problem.
Hope this helps. Good luck!
Erik Lindahl
April 12, 2006 at 8:53 amOkej. The problem is the same as with After Effects. I have to set the footage field-domninace to NONE or it gets 50% lower resolution. Irritating, but it works.
Now I noticed that Motion won’t respect filters but on clips in Final Cut. This REALLY sucks I must say since Final Cut has the three-way color corrector and motion doesn’t
