Activity Forums DaVinci Resolve semi transparent bars when exporting a 4096×2732
  • semi transparent bars when exporting a 4096×2732
    Posted by Laura Fernandez on March 27, 2021 at 10:59 am
    Hi there!
    I have a project and all the clips have a native resolution of 4096×2732.
    When I set up the timeline to this resolution and I export on this resolution I get semi transparent bars on top and bottom. They look like a letterbox with 50% opacity…
    What can I do to get the image without this bars?’
    Thank you!!!!
    David Baud replied 5 years, 6 months ago 2 Members · 1 Reply
  • David Baud
    March 27, 2021 at 7:15 pm
    It depends on what your master delivery frame size and aspect ratio are?
    If you’d like to fill the frame with your footage, depending the workflow stage you are at, I can see at least 2-ways to deal with this:
    . go to File > Project Settings > Image Scaling and select Scale entire image to fit in Input scaling and/or Output scaling
    . In your EDIT page, select the clip and in the Inspector panel, under Transform, adjust the Zoom settings to your liking
    Also if you’d like to output a letterbox format (black bars), go to Timeline > Output blanking and select the appropriate letterboxing format.
