Activity › Forums › Apple Final Cut Pro › Semi opacity on a multicam clip?
  • Semi opacity on a multicam clip?
    Posted by Martin Phillips on April 29, 2014 at 10:14 pm
    Just putting a 12 cam live concert together. Would really like to have the piano keyboard dipping in and out behind the singer (for example) on a semi-opacity. What’s the best way to go about this?
    Many thanks.
    Martin Phillips Freelance Cameraman / Producer / Editor
    Chesham, Buckinghamshire, UK. http://www.thevideodepartment.co.uk
    James Cude replied 12 years, 5 months ago 2 Members · 1 Reply
  • James Cude
    April 30, 2014 at 12:35 am
    You can only show one angle at a time in a multicam clip. So the easiest way to do what you want would be to duplicate the multicam clip, connect it above the multicam clip as a connected clip and then switch to the desired angle and dial down the opacity. Then you’ll have two instances of the same clip, showing different angles.
