Activity › Forums › Adobe After Effects › self designed particle emmiter
Posted by Unai Guerra on February 28, 2006 at 3:44 pmDoes anyone know any plugin that creates an user designed particles emmiter?
IJoseph W. bourke replied 20 years, 6 months ago 4 Members · 4 Replies -
Jeff Dobrow
February 28, 2006 at 4:03 pmYou can use Particular to emit any type of particle you want. Including animating particles, and even different particles every frame……
Use custom particle type. You can use a comp as a particle for including animating particles. And you can precomp comps or particles into a comp at every frame and use the ‘birth’ options to sample which particles to emit and when……..
Heather Memmel
February 28, 2006 at 5:16 pmThere is a demo on Trapcodes website that shows you how to do this exact thing.
Joseph W. bourke
February 28, 2006 at 6:00 pmHere’s a link to a tutorial by Roland Kahlenburg that shows you how to do it without a third-party plugin, just in case you don’t own Particular.
I’ve experimented with getting this to work on a basic level in Particle Playground, and as long as you have the layer you want emitted in your timeline, it works just fine. Good luck.
Joe Bourke
Art Director / WMUR-TV
